VLAN VTP
mansoor_nawaz78
i configur a new switch, and i set it as a VTP client, but VLAN database is not activated, VLAn are not updated
ankurbhasin
Level 9
Level 9
Hi Mansoor,
By default all the switches are in VTP server mode till the time you manually change the VTP mode.
Now if it is in client mode and not updating the vlan you have to make sure that there is a proper trunk config between the server switch and the client switch and the VTP domain name and password should match on VTP server and client.
HTH, if yes please rate the post.
Ankur
sh VTP status
VTP Version : 2
Configuration Revision : 0
Maximum VLANs supported locally : 250
Number of existing VLANs : 5
VTP Operating Mode : Client
VTP Domain Name : metro
VTP Pruning Mode : Enabled
VTP V2 Mode : Enabled
VTP Traps Generation : Disabled
sh VTP counter
VTP statistics:
Summary advertisements received : 4
Subset advertisements received : 2
Request advertisements received : 0
Summary advertisements transmitted : 0
Subset advertisements transmitted : 0
Request advertisements transmitted : 2
Number of config revision errors : 0
Number of config digest errors : 2
Number of V1 summary errors : 0
these are two results which show the information, regarding to VTP.
If server has a VTP password, but on client side password is not configured.
Hi Mansoor,
You have a password mismatch.
Check this from your output
This means there is a password mismatch so just configure the same passoword on your VTP client switch and everything will work fine.For VTP to work fine you need to match the domain name and password on Server and client switch.
Ankur
