Codec Issue on IPCC Express
Answered Question
Apr 3rd, 2006
Hi Pros,
I have a IPCC Express 4.0 Enhanced Setup. Now, I had selected G.711 as codec for IVR prompts during CRS install. Is there a way I can change the codec type to G.729 without reinstalling CRS. And also, can I use transcoding services if my caller uses G.729 & IPCC Express uses G.711 as IVR Prompts.
Pratik
Correct Answer by thisisshanky about 11 years 4 months ago
You can use only one codec as of today with ipcc express. Its chosen during installation phase. It can be changed only by reinstallation. You will need to use a hardware transcoder to translate calls between g729 and g711 to work with IPCC. I would suggest that you install g711 on your IPCC, unless you have a lot of remote agents.
Correct Answer by Chris Deren about 11 years 4 months ago
You will need to re-run setup to change it to G.729.
Yes, you can use transcoders to transcode between codecs.
Rate helpful posts!
Chris
Overall Rating: 5 (3 ratings)
Correct Answer
Chris Deren Mon, 04/03/2006 - 04:39
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Rate helpful posts!
Chris
Correct Answer
thisisshanky Mon, 04/03/2006 - 22:48
  • Purple, 4500 points or more
