Warning message
NAT config
Apr 3rd, 2006
Dynamic NAT is not working with the following config. Could you assist with configuration.
Thanks.
Said
version 12.3
hostname NAT
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
ip cef
no ip domain lookup
ip audit po max-events 100
no ftp-server write-enable
interface Ethernet0/0
ip address 193.168.1.1 255.255.255.0
ip nat inside
half-duplex
interface TokenRing0/0
no ip address
shutdown
ring-speed 16
interface Serial1/0
ip address 200.200.100.1 255.255.255.252
ip nat outside
no fair-queue
interface Serial1/1
no ip address
shutdown
interface Serial1/2
no ip address
shutdown
interface Serial1/3
no ip address
shutdown
ip nat pool public 200.200.100.129 200.200.100.250 netmask 255.255.255.128
ip nat inside source list 1 pool public
ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 200.200.100.2
access-list 1 permit 193.168.1.0 0.0.0.255
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
login
end
dgahm Mon, 04/03/2006 - 11:23
  • Blue, 1500 points or more
The return packets to your pool addresses are probably being dropped.
Can you change the subnet mask on S0 and the adjacent router to include your NAT pool range? That would fix it. Or you could add a static route on the adjacent router pointing your pool subnet back to 200.200.100.1.
Please rate helpful posts.
Nicholas Vigil Mon, 04/03/2006 - 13:07
It might be easier to PAT your internal address as follows:
ip nat inside source list 1 interface Serial1/0
overload
This will translate all yout internal address to your serial IP using PAT.
