CUE custom prompts for voicemail
Apr 3rd, 2006
I would like to know if it is possible to modify the prompts the user listen when trying to retrieve voice mail messages. I know I can change the AA prompts and script, but I would like to modify also the voicemail application prompts.
Brandon Buffin Mon, 04/03/2006 - 20:31
  • Purple, 4500 points or more
I had the same question. See the post below for the response from Cisco. If you're having your prompts professionaly recorded, one solution is to give the company access to call in to the mailbox and record the greeting.
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=IP%20Communications%20and%20Video&topic=Unified%20Communications&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dda4689/0#selected_message
Hope this helps.
Brandon
