Warning message
2950 problems
Apr 3rd, 2006
i have 2950 switch and the console port stop work
i can access it by Vty
but one of students change the enable password what i do to recover password and access it
mg_123 Tue, 04/04/2006 - 04:56
hi , thanks for fast response
but as i say the console port have a problem ,
how i recover password ,while the console port out of work {i can access it by VTY }
amit-singh Tue, 04/04/2006 - 05:03
  • Blue, 1500 points or more
Did you try changing the different baud-rate or terminal emulation program.
If yes then,Sorry to say but if console port is dead you cannot recover it.
Go ahead and get the replacement for it. Open a TAC case and get a replacement 2950.
HTH, Please rate if it does.
-amit singh
