Warning message
IGESM in IBM Blade center
Apr 4th, 2006
Hi all,
Is anybody knows how to get telnet access to IGESM in IBM blade servers?
basically i need to enable trunking between this module and uplink switch.
Thanx in advance.
Rajesh
glen.grant Tue, 04/04/2006 - 05:56
  • Purple, 4500 points or more
This done by the actual management module of the blade server itself , you actually telnet thru the blade server management module to the cisco switches in the blade server. Whoever is in charge of the blade server should be able to set this up and assign addresses for your switches.
