Warning message
How to capture switch config from Hyperterminal
Apr 4th, 2006
Hi!!! I tried to capture configuration reports of a switch which i did from Hyperterminal.I went to the menu bar which in the top and went to transfer ,on the dropdown it says capture text.I did that but when i opened the captured file i can see the text scattered here and there.Is is possible to see the captured configurations of the switch as how we see organised in the hyperterminal.Can u pls tell me ,do i need to do any configurations in the hyperterminal before i could start capture text.
thanks and regards
spremkumar Tue, 04/04/2006 - 06:29
  • Red, 2250 points or more
hi
try opening the file either with wordpad or notepad.
sometimes it works fine with wordpad not though with notepad..
regds
Nicholas Vigil Tue, 04/04/2006 - 06:30
If you open the file using notepad it tends to scatter the text. Have you tried veiwing the file using wordpad instead?
jlwomeld Wed, 04/05/2006 - 11:14
on the hyperTerm
go to tranf
capture and give your file a location ex:c:\temp\test.txt and then hit the start button.
do a sh run on device.
