Warning message
config E1 on serial port ?
Apr 4th, 2006
Dear all,
I have a Cisco 3660 router with Serial4T card and need to config E1 on these ports. Please help with the config. Thank you very much.
Duc Vu
P.S. Here is router's info:
interface Serial3/0
no ip address
shutdown
Serial3/0 is administratively down, line protocol is down
Hardware is QUICC Serial
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
Encapsulation HDLC, loopback not set
Keepalive set (10 sec)
Mueslix-4T Port adapter, 4 ports
Port adapter is disabled deactivated
Port adapter insertion time unknown
EEPROM contents at hardware discovery:
Hardware revision 1.1 Board revision D0
Serial number 14440376 Part number 800-02314-02
FRU Part Number: NM-4T=
Test history 0x0 RMA number 00-00-00
EEPROM format version 1
EEPROM contents (hex):
0x20: 01 54 01 01 00 DC 57 B8 50 09 0A 02 00 00 00 00
0x30: 68 00 00 00 99 05 17 00 00 05 FF FF FF FF FF FF
spremkumar Wed, 04/05/2006 - 02:04
  • Red, 2250 points or more
hi
Can you paste the show version output taken from your router so that the compatibility of the card to ur chasis can be found ?
i feel this message indicates that the particular card is not supported by the chassis in which you are installing the same.
"Port adapter is disabled deactivated"
output of show diag will also help to understand the exact problem ..also mention the type of the card which you are trying to install over there in ur router ...
regds
