Warning message
Does BPDU-Guard cause an STP re-calculation?
Answered Question
Apr 4th, 2006
I am enabling this feature on my switches and understand it only affects portfast enabled ports but are there any spanning-tree convergence issues when I issue this command on a switch? I don't want to bring down my lan from an stp perspective.
Any replies would be appreciated.
-Ken
Correct Answer by sundar.palaniappan about 11 years 4 months ago
Ken,
I didn't think it would cause any STP reconvergence. I enabled it in a lab switch and didn't see any issues. Looks like you can safely turn on the feature.
HTH,
Sundar
Overall Rating: 5 (1 ratings)
b-ulrich Tue, 04/04/2006 - 13:22
  • Bronze, 100 points or more
Are you doing this in global or on the interface level? I have gone thought this for a network and did not have any STP issues at all.
Correct Answer
sundar.palaniappan Tue, 04/04/2006 - 15:43
  • Green, 3000 points or more
Ken,
HTH,
Sundar
