Warning message
wawan_cisco Wed, 04/05/2006 - 04:36
Thank's Mr. Paresh for your reply.
But the problem is the Mode Button is not work or crash.
Pls another solution
Wawan Kurniawan
amit-singh Wed, 04/05/2006 - 04:42
  • Blue, 1500 points or more
Another thing you can try it to break the booting sequence. Reboot your switch and press ctrl+break key and it should take you to the rommon. It may not work on your switch but you can give it a try.
You can then follow the recovery procedure if it gets you in.
Otherwise get switch replaced as the mode button is crashed.
HTH, Please rate if it does.
-amit singh
