Warning message
VLAN Bandwidth Management
Apr 5th, 2006
Can i manage bandwidth for a VLAN, I mean can i fix a Bandwidth on VLAN, e.g,
If i apply 250Kbps for a VLAN 101 , evry client shared this bandwidth, if total customer in VLAN 100 is 10, each use 25Kbps bandwidth .
Thank You.
leighharrison Wed, 04/05/2006 - 02:25
  • Gold, 750 points or more
Hi there,
Yes you can do this, but you would do it in QoS. In the class-map you would match on either the vlan or the IP address and then in the policy-map, you would shape to 250k on the egress ports on the box
That would sort it.
LH
mansoor_nawaz78 Wed, 04/05/2006 - 03:32
Thank You for a response,
I have a 3550(VTP mode Server) where all VLANs are established, and other 2950(VTP Mode Client) are connected with this 3550 Switch, If i developed a policy of 250Kbps on a 3550 accross a VLAN will it start to work ?
leighharrison Wed, 04/05/2006 - 06:14
Hey there,
Yes it will - providing you've got the layer 3 functionality. In the class map, match on either the vlan or ref. an access list and grab the network range. The other vlans/networks will not be referenced and will take as much bandwidth as they can (as per normal)
LH
