Warning message
Pix Firewall Interface Configuration
Answered Question
Apr 5th, 2006
On a PIX 525 running ver 6.3 with a 4 port 10/100 card installed will it be possible to configure the interfaces as follows:
e0 - Inside interface
e1 - Firewall stateful failover
e2 - Firewall Failover monitoring link
e5 - Outside interface
I am basically unsure as to whether is is possible to move the outside interface from it's default configuration as e0 to e5 and similarly if it will be possible to specify e0 as the inside interface instead of the default confiuration of e1=inside.
One other quickie - I assume that with the additional 4 port 10/100 card installed my interfaces will be numbered e0-e5. Is that correct?
Thanks.
Correct Answer by m.sir about 11 years 4 months ago
Some Cisco documentation says that is not possible to change name and security level of inside interface but i have experience that is possible:
nameif ethernet1 failover security50
nameif ethernet5 outside security0
etc...
I wouldn't recommend doing it in a production environment since it would create a lot of confusion...
525 has two fixed interfaces e0 e1 - so expansion 4 port card should be numbered e2, e3 (from left to right)
M.
Hope that helps rate if it does
Overall Rating: 5 (1 ratings)
Correct Answer
m.sir Wed, 04/05/2006 - 10:15
  • Gold, 750 points or more
etc...
M.
srowles Thu, 04/06/2006 - 04:50
Thanks for the reply.
I have now been able to test this and was able to configure the following using ver 6.3(3)
nameif ethernet0 inside security100
nameif ethernet1 stateful security10
nameif ethernet2 failover security20
nameif ethernet3 intf3 security6
nameif ethernet4 intf4 security8
