Warning message
Port Security 4500
Apr 5th, 2006
I'm attempting to implement port security on a 4506 and I believe I have it configured correctly but it acts as if it is instantly aging. (i.e. I can't get it to trigger) When MAC A is on port 2/1, the secure MAC shows MAC A and the Last Secure MAC as MAC A. Also the cam creates a static entry for it on 2/1.
Then I unplug MAC A and plug in MAC B and it simply adjusts. Now instead of shutting down like it's configured to do, it shows MAC B as the secure MAC and Last Secure MAC and also the static cam entry changed. Does anyone know how to get the MAC to stay and get the port to trigger? There is no age timer, and the max is set to 1. Thanks
Chris
Overall Rating: 4 (1 ratings)
Nicholas Vigil Wed, 04/05/2006 - 13:00
To enable port security use the following:
set port security [mod/port] enable
set port security [mod/port] maximum 1
set port security [mod/port] violation shutdown
I hope this helps.
ankurbhasin Wed, 04/05/2006 - 20:14
  • Red, 2250 points or more
HI Chris,
AFAIK port security is either autoconfigured or enabled manually by specifying a MAC address and in your case it is auto configured. If a MAC address is not specified, the source address from the incoming traffic is autoconfigured and secured, up to the maximum number of MAC addresses allowed.
These autoconfigured MAC Addresses remain secured for a time, depending upon the aging timer set. The autoconfigured MAC Addresses are cleared from the port in case of a link-down event.
Now when you unplug the MAC A a link-down event will occured and will definetely clear the last mac address A leanred at that port 2/1.
The max set 1 command is just that only 1 mac address will be allowed on that port at a time so that no one can connect a hub and connected many machines to that port , this command will not let the switch to retain the mac address when you unplug the machine.
Also configure the violation conditon
set port security mod_num/port_num violation {shutdown | restrict}
Have a look at this link for more details
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/8_1/config/sec_port.htm#1023061
HTH, if yes please rate the post.
Ankur
chris.stepniewski Thu, 04/06/2006 - 08:27
Ankur,
Thank you, that explains why I'm having the issue, but now I must ask the question: Is there a way to make the port keep the learned address after a link-down event with out having to type each MAC I want to secure? (e.g. a mac-address-sticky command like on the IOS based switches.) I didn't see one in the literature but hopefully someone knows some obscure command.
Thanks again,
Chris
trangen Thu, 04/06/2006 - 14:18
in order for it to stay, you have to configure it to be static; e.g.
switchport port-security mac-address xxxx.xxxx.xxxx
switchport port-security violation shutdown
chris.stepniewski Fri, 04/07/2006 - 04:23
I understand that I can type in each MAC, what I'm asking is:
Can you have the switch learn and retain each MAC after a link-down event without having to type each MAC. No is a valid answer, I just want to make sure I'm not over looking anything.
Chris
