Warning message
How to enable dot1x multiple-authentication
Answered Question
Apr 5th, 2006
Help
How can I enable dot1x multiple-authentication on 2948G. The image is 8.2(GLX).
Thanks in Advance
Matt
Correct Answer by sundar.palaniappan about 11 years 4 months ago
I am quoting it (see below) from the link I sent to you in the previous post. Based on that it looks like it's supported on the 2948G switch
The Cisco Catalyst® Operating System (Catalyst OS) Software Version 7.5(1) for the supervisor engine supports the Cisco Catalyst 6500 Series and Cisco Catalyst 4000/4500 Series multilayer switches (including the Cisco Catalyst 2948G, 4912G, and 2980G-A switches).
Pls. rate all helpful posts.
HTH,
Sundar
Overall Rating: 4 (2 ratings)
sundar.palaniappan Wed, 04/05/2006 - 19:53
  • Green, 3000 points or more
Matt,
AFAIK, dot1x multiple host authentication isn't supported on 2948G switch.
HTH,
Sundar
mattkaya56 Thu, 04/06/2006 - 09:43
Thanks for the response.
Any other product other than Cat6500 that supports this?
Matt
sundar.palaniappan Thu, 04/06/2006 - 09:53
Matt,
3550/4500 switches support multi-host feature. There may be more products out there.
Pls. rate helpful posts.
--Sundar
mattkaya56 Thu, 04/06/2006 - 14:33
Hello Sundar,
Multi-host does not give me what I want. I am looking for set port dot1x mod/port multiple-authentication which will force every mac on the port to undergo dot1x authentication. In the case of Multi-host only one of mac's need to authenticate - all the rest ride in for free.
I did locate a version 8.1 that supported this feature - can you please confirm if this is true.
Matt
mattkaya56 Thu, 04/06/2006 - 15:38
Thanks again Sundar
Will it work on 2948G - according to 8.1 Command ref manual it does. Could you please confirm.
Matt
Correct Answer
sundar.palaniappan Thu, 04/06/2006 - 15:45
HTH,
Sundar
