Warning message
Spreading users across multiple AP's
Apr 6th, 2006
I have a requirement to provide Wireless to over 250 people in one big arena. I am thinking of using an Lwapp install but was wondering how will I force users to associate evenly across all access points. I want to avoid the situation whereby 30 associate with AP1 and 5 associate with AP2
Any help would be appreciated
karthiknarasimhan Tue, 04/11/2006 - 21:36
Hi Martin,
Hope so everything's fine at your end.
Typically Ap1200's or LWAPP AP's manage load balancing internally on their own using the Auto-RF features if you are using some 4000 series controllers dunno about others. So this auto-rf features should equally load balance the client across all Ap's, well if that doesn't happen for som e reason then, you may change the configuration to do that.
You may create seperate wlans to be broadcasted through different lwapps with seperate ssid's.
For example,
AP1200-1 broadcasts wlan 1 connecting around 35 clients
AP1200-2 broadcasts wlan 2 connecting another set of 35 or more.. and so on.
AP1200-3 broadcasts wlan 1 again but is at a distance of say more than 100 feet or so connecting another set of 35 or more.. and so on.
Please feel free to contact me if you need any more assistance.
Thanks & Regards,
Karthik Narasimhan
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
