837 ADSL PPTP- no DNS?
Apr 6th, 2006
Hey folks, hoping someone can help me with this.
Probably pretty simple for most of the minds here, but I'm trying to get a Cisco 837 router (on a 2Mb ADSL connection) working as a PPTP terminator.
I've got what I think is close to a working config; I haven't yet tried PPTP from the outside, however, as I've noticed that this config does not seem to allow me to perform domain lookups. Ie; 'nslookup' from an MS command prompt 'times out' when attempting to contact DNS servers. Name lookups then result in nothing.
The DNS servers are there and alive; I have verified this by reverting to my basic config, and all is then well.
Anyone have any ideas? Config (sanitised) is below.
TIA-
version 12.3
service config
no service pad
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname (changed)
boot-start-marker
boot-end-marker
enable secret (changed)
no aaa new-model
ip subnet-zero
ip name-server 194.x.x.34
ip name-server 194.x.x.38
ip audit notify log
ip audit po max-events 100
ip ssh break-string
vpdn enable
vpdn-group pptp
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 1
no ftp-server write-enable
no scripting tcl init
no scripting tcl encdir
no crypto isakmp enable
interface Ethernet0
ip address 192.168.4.254 255.255.255.0
ip nat inside
hold-queue 100 out
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
hold-queue 224 in
interface FastEthernet1
no ip address
duplex auto
speed auto
interface FastEthernet2
no ip address
duplex auto
speed auto
interface FastEthernet3
no ip address
duplex auto
speed auto
interface FastEthernet4
no ip address
duplex auto
speed auto
interface Virtual-Template1
no ip address
peer default ip address pool pptp
ppp encrypt mppe 40
ppp authentication ms-chap
interface Dialer0
ip address (external net, /29)
ip access-group 102 in
no ip redirects
no ip unreachables
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname (hostname)
ppp chap password (password)
ip local pool pptp 192.168.4.240 192.168.4.245
ip nat inside source list 101 interface Dialer0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
access-list 101 remark The local LAN.
access-list 101 permit ip 192.168.4.0 0.0.0.255 any
access-list 102 remark traffic allowed in from internet
access-list 102 permit udp any any eq domain
access-list 102 permit tcp any any eq domain
access-list 102 permit udp any eq isakmp any eq isakmp
access-list 102 permit tcp any any eq 1723
access-list 102 permit gre any any
access-list 102 permit icmp any any unreachable
access-list 102 permit icmp any any echo-reply
access-list 102 permit icmp any any packet-too-big
access-list 102 permit icmp any any time-exceeded
access-list 102 permit icmp any any traceroute
access-list 102 permit icmp any any administratively-prohibited
dialer-list 1 protocol ip permit
control-plane
line con 0
password (changed)
login
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
password (changed)
login
transport input all
scheduler max-task-time 5000
s.jankowski Wed, 04/12/2006 - 07:39
  • Bronze, 100 points or more
I see "no ip address" command under your virtual-template 1 interface configuration. When the virtual-access interface is dynamically created, it will need an IP address. Usually this can be an "ip unnumbered" from another interface.
Another suggestion is try your connection without ppp encryption to make sure the basic setup is working fine.
0r8it Thu, 04/13/2006 - 02:06
Thanks, I'll try that. I'll set the virtual-template 1 to pick up IP unnumbered from the Dialer0.
PPP is necessary- the ISP requires it for authentication.
regards-
