Warning message
DS3's limit on a 7206
Answered Question
Apr 6th, 2006
Can any tell what is the limit or how many ds3's can be installed in one 7206vxr router.With Cisco 7206VXR (NPE-G1) processor (revision B) with 491520K/32768K bytes of memory.
125184K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
16384K bytes of Flash internal SIMM (Sector size 256K).
Any help will be appreciated
Thanks.
Correct Answer by pkhatri about 11 years 4 months ago
Based on bandwidth points calculation alone, you should be able to populate all 6 slots of the 7206 with DS3 cards, even if they were the 2-port DS3 cards. That means you could have a theoretical maximum of 12 T3 ports on a 7206VXR. In practice, however, that would seem unlikely...
However, there is nothing stopping you from doing so.
Hope that helps - pls rate the post if it does.
Paresh
Overall Rating: 5 (1 ratings)
Correct Answer
pkhatri Thu, 04/06/2006 - 14:25
  • Purple, 4500 points or more
Paresh
