Warning message
CCM 5.0 - ccmadmin login information
Apr 6th, 2006
Just installed a fresh copy of CCM5.0, I browse to http://ccm5srv:8080/ccmadmin and it prompts me for a username and password... Everything that I try to enter here returns fails to log me in.
I've tried, Administrator, admin, CCMAdministrator, etc... I can't figure out which one to use. I am able to access the IPTPlatform pages and I do have access to the CLI admin via SSH.
Is there a way to reset the username and password for the ccmadministration?
gajolly Thu, 04/06/2006 - 20:09
I dont whether it will help you or not but check under SQL - MLA parameter table MLA value is F if its True set it to false save the changes and then try to access you server.
aaronw.ca Fri, 04/07/2006 - 04:55
  • Silver, 250 points or more
The admin username is CCMAdministrator (in my experience), and the password for CCMAdministrator is set during installation.
You should be able to log into the console and use the CLI to change the password.
Kirill Klimakhin Fri, 04/07/2006 - 05:10
Yes... I am able to login to the CLI, but I can't figure out how to change the CCMAdministrator password...
Abdul Rahman Fri, 04/07/2006 - 21:23
  • Cisco Employee,
During the installation you are prompted to set 4 different passwords.
1. Platform admin and password. - This user id / pwd
is used to SSH to the appliance and also to
access the platform webpages. The same user id /
pwd is used to access the Backup/Restore application pages.
2. Security password - cluster security password
used between the nodes in a same cluster.
3. Close to the end of the installation you will
be prompted to set the default application user
password - This password is the default password
for all the application user. CCMAdministrator
is an application user so whatever password
that was set as default for the application user
is the password for CCMAdministrator.
4. You will also be prompted to set the default
password for all the CCM Users (You may not see
this during fresh install, I think this is specific to CM4.X to CM5.X upgrade.
From the admin CLI you can change the Platform administrator password and security password. You don't have the option to change the CCMAdministrator password.
