Connectivity check
Apr 7th, 2006
Hi all,
I performed the connectivity check on communication between 2 sites. Local host can ping to remote host and vice versa, without problem.
I am using a common ping test, with 5 packets. But when I tried to browse the remote web server or file shares, or any application, it failed at all.
What further ping or other further test(s) should I perform in order to really ensure that the connectivity is really in the good working condition?
Thanks in advance!
pciaccio Fri, 04/07/2006 - 04:42
  • Silver, 250 points or more
Try using a program like IPerf (freeware). This program can tell you how you pass TCP or UDP traffic and can also flood your network to load test your links. However you may be blocking some ports for the application. Pings are great for low level connectivity tests, but does not test any upper layer ports and applications.Double check your routers/switches to assure there are no restrictions on your network blocking the traffic.
chengsh832478 Sun, 04/16/2006 - 20:46
By the way, where to check those ports are being blocked in the switches ?
Roberto Salazar Sun, 04/16/2006 - 20:58
  • Gold, 750 points or more
along the path there may be ACL configure on the routers that blocks the L4 port of the application. Taking a sniffer might shed some light on why it's failing but you need to find first where it's getting dropped or failing these applications.
chengsh832478 Mon, 04/17/2006 - 20:13
There are no router being used between these switches. Hence, no ACL. I checked the Switch config file, none of the settings seems to block certain ports.
What else?
