Warning message
Cisco UDLD with non-Cisco device
Answered Question
Apr 7th, 2006
Hi all,
Can UDLD still work when Cisco switches with UDLD connect with other device without UDLD, like router etc.?
mak
Correct Answer by Bobby Thekkekandam about 11 years 4 months ago
Hi Mak,
No, both sides of the link must support UDLD for it to work properly.
see: http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/122sx/swcg/udld.htm
" Devices on both ends of the link must support UDLD in order for the protocol to successfully identify and disable unidirectional links."
HTH,
Bobby
*Please rate helpful posts.
Overall Rating: 5 (1 ratings)
Correct Answer
Bobby Thekkekandam Fri, 04/07/2006 - 08:47
  • Cisco Employee,
Hi Mak,
HTH,
Bobby
