Extension Mobility - 7912 loses Services
Apr 9th, 2006
I am using Extension Mobility and we have a lot of 7912 phones that we are using the service with.
When logging onto Extension Mobility or when logging out of Extension Mobility the services option is lost from the phone.
Doing a **#** reset brings the service back, but is there anyway to cause the phone to hard reset whenever Extension Mobility is logged in/out?
Other than this error, the 7912 phones seem to work fine with Extension Mobility.
Thanks.
thisisshanky Sun, 04/09/2006 - 21:23
  • Purple, 4500 points or more
What version CM is this ? Have you subscribed the UDP with logout service ? What happens when you hit the services button after loggin in ?
jason.panosh Sun, 04/09/2006 - 21:34
Thanks for the quick reply.
My version of CCM is:
System Version 3.3(4)sr2.
Administration Version 3.3(0.161)
Installation ID 3.3(4)sr2
Ok, now you need to tell me what UDP represents in this context, it is normally a networking protocol, so I do not think that would be right in this context.
Just as reference, normally our phones have 1: Messages, 2: Directories, 3: Settings, 4: Services
What I have seen so far:
Case 1: When I login, the option 4: Services is not available. Reset phone it is back.
Case 2: When I login the option 4: Services is there, but when I logout it is not there until I reset the phone.
Case 3: After logon and logout the option is there, but after the Auto Logout period expires the option is gone.
Thanks.
jason.panosh Mon, 04/10/2006 - 01:15
Hello Bernhard,
I could not navigate to the URL you posted. I have contacted Cisco to find out about this.
Thanks.
thisisshanky Mon, 04/10/2006 - 09:10
The bug id says this:
Symptom:
7905 and 7912 phones lose service softkey after EM phone config activation.
Conditions:
7905, 7912 phones
Workaround:
none unless use phones other than 7905 and 7912.
Here are the versions on which this problem is fixed.
4.1(3)ES38, 4.1(2)ES61, 4.0(02a)ES66, 3.3(5)ES33,
