Etherchannel ???
Apr 10th, 2006
Hi ,
when i am configuring etherchannel with both the sides channel mode ON with 'channel-group 1 mode on'
that means nowhere i am using either pagp and lacp for formation of etherchannl and even for load balancing among interfaces ...am i correct or wrong?.
Rajesh
Overall Rating: 4 (1 ratings)
Bobby Thekkekandam Mon, 04/10/2006 - 05:04
  • Cisco Employee,
Hi Rajesh,
Yes, you are correct. Using mode ON disables PAgP and LACP negotiation.
HTH,
Bobby
*Please rate helpful posts.
mahmoodmkl Mon, 04/10/2006 - 05:06
  • Gold, 750 points or more
it is going to perfrom load-balancing automatically
Mahmood
Bobby Thekkekandam Mon, 04/10/2006 - 05:13
  • Cisco Employee,
Hi Mahmood,
Yes, PAgP and LACP are protocols that serve only to negotiate the channel. It is recommended to enable them if possible as these protocols also provide inherent error detection capabilities.
The load balancing aspect of the etherchannel is built into the hardware, so once the channel index is programmed into the port ASIC, the load balancing algorithm automatically distributes the traffic among the ports, depending on the configured scheme (SRC and/or DST MAC and/or IP, etc.)
HTH,
Bobby
rajeshk200_2 Mon, 04/10/2006 - 05:20
Bobby,
I was thinking same as you said. I am thinking PAGP only for finding capable ports ,automatic negotiation and adding those ports in to etherchannel...other then this there is no role for pagp in etherchannel
Do you agree with me ? or i am misunderstood.
Rajesh
Bobby Thekkekandam Mon, 04/10/2006 - 05:23
  • Cisco Employee,
Rajesh,
You are mostly correct. The other role for PAgP is to maintain the integrity of the channel. Should a problem occur on a link (such as a marginal port, etc.), PAgP would disable the channel, whereas with mode on, the channel stays up as long as the physical link is up. Cisco's recommended best practice is to use PAgP or LACP for channel negotiation.
HTH,
Bobby
rajeshk200_2 Mon, 04/10/2006 - 05:15
Mahmood,
U mean to say for load balancing it will use pagp..
Rajesh
mahmoodmkl Mon, 04/10/2006 - 05:35
HI
No as bobby said that PAGP and LACP are used to find the channel capable ports i think it has nothing to do with load-balancing.as bobby said it all depends which method u use.ie based on source or destination mac or IP.
Mahmood
