Warning message
ACL doubt
Apr 10th, 2006
  • Silver, 250 points or more
interface vlan 5
ip address 192.168.1.1 255.255.255.255
ip access-group 101 in
ip access-group 102 out
interface vlan 6
ip address 10.2.1.1 255.255.255.0
access-list 101 permit ip 192.168.1.0 255.255.255.0 10.2.1.0 255.255.255.0
access-list 102 permit 10.2.1.0 255.255.255.0 192.168.1.0 255.255.255.0
which means 101 says that vlan 5 will permit vlan 6 inside & 102 says that vlan 5 will reach vlan 6 out
can i use in this mannaer
access-list 101 10.2.1.0 0.0.0.255
access-list 102 192.168.1.0 0.0.0.255
is that the same?
Harold Ritter Mon, 04/10/2006 - 07:37
  • Cisco Employee,
I suppose you are referring to standard ACLs, in which case the ACL number has to be below 100 (1 through 99).
The standard ACL only checks against the source address, whereas the extended ACL (100 through 199)checks both the source and destination. Extnded ACL is a lot more powerful since it allows to specify the protocol, source and destination protocol ports, etc. etc.
Hope this helps,
Anand Narayana Mon, 04/10/2006 - 07:42
thanks hritter, my doubts got cleared, also can i use "n" number of access-list in my router or does it hav eany limitation if i use Extended ACL or Standard ACL, already i have created ACL nearly 100 lines, so will it permit more than that also?
Harold Ritter Mon, 04/10/2006 - 10:59
  • Cisco Employee,
100 lines is quite conservative compared to what I have seen being used by some customers in the past.
Hope this helps,
