gogasca Mon, 04/10/2006 - 15:21
  • Green, 3000 points or more
CSCea08607 which is a request to add corparate directory support.
The below link confirms it.
http://www.cisco.com/en/US/customer/products/hw/phones/ps379/products_qanda_
item09186a00801a22f1.shtml#q1-3
But...
You need to upgrade the 7920's to 2.0 firmware. Downloading the latest Dev-Pack off of CCO and installing it on your Callmanagers will add and
update your Callmanager to provide the phone the newest firmware the next time the phone is rebooted.
//G
roysand2002 Tue, 04/11/2006 - 05:24
I already have firmware version 2.0. The Corporate Directory shows up under menu+Directory. When you select Corporate Directory it says " Request Fail "
Thank you,
gogasca Tue, 04/11/2006 - 12:24
CSCsb07328
CSV and XML files for Baker Project should be updated to reflect new fea
Release 2.0 of 7920 firware requires modifications
to the following CSV and XML files in CCM to support new features:
7920 display instance.xml
7920 XML Rules.xml
Product_30002.csv
List of new features in release 2.0:
- Support for XML Applications
- Support for 7920 Specific Settings:
. CCM Control of Enabling/Disabling Local Phone Configuration.
. Setting of softkey label for Phone Book (PhBook) or IP Phone Services (Svcs) when the phone is idle.
. Control of initial softkey labels that are displayed after a call is established.
I think should be fixed in:
004.002(000.368) 03.3(05)ES13 04.0(02a)ES41 04.0(02a)SR02b 04.0(02a)SR02c 04.1(02)ES35 04.1(03)ES08 04.1(03)SR01
