Warning message
sccp gateway or proxy / VPN's and IPCommunicator
Apr 11th, 2006
Hi all,
I am searching for a solution of some kind of sccp proxy. I do not want to propagate all possible subnets with SCCP-Phones to the VPN Client/IPCommunicator.
I would like to have a gateway where all SCCP-Phones coming from the VPN-Subnets communicate with the ccm's and the "gateway".
I think this must be already invented ;-)
mchin345 Mon, 04/17/2006 - 07:44
  • Silver, 250 points or more
The Firewall Support of Skinny Client Control Protocol (SCCP) feature enables Context-Based Access Control (CBAC) inspection to support the Voice over IP (VoIP) protocol, Skinny Client Control Protocol (SCCP). That is, CBAC inspects Skinny control packets that are exchanged between a Skinny client and the Call Manager (CM); CBAC then configures the router (also known as the Cisco IOS Firewall) to enable the Skinny data channels to traverse through the router.
Try:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080455cb2.html
bsiegenthaler Tue, 04/18/2006 - 04:12
This is not exactly the problem.
The packets can pass.
As it is known IP-Phones communicate via rtp.
Now, if you have 100 voice-subnets, You have to propagate every subnet to the VPN-Client.
I search some kind of Media-Termination-Point for Ip-Phones inside the same Net with CCM.
Then the IP-Phones do communicate with this MTP and not with outside IP-Communicators. On the other Side, IP-Communicators do communicate only with this Point and must not have access in every phone-subnet.
Same effect as when you do a conference. All endpoinds communicate\terminate with the ccm.
I searching also in the gatekeeper functions to solve this.
Maybe http://www.metreos.com/products/phone-proxy.shtml could be also a solution.
