New 2800 router and 9 PT HWIC
I can not ping my phone extender 172.16.5.5 with this current setup.....why? The extender is connected to the switch and the 5.1 port is connected to the switch as well. I read about what is required to stack the HWICs but I am not doing that.
Building configuration...
Current configuration : 2749 bytes
version 12.3
hostname SIVLFtoNOR
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
enable secret xxxx
enable password xxxx
no network-clock-participate aim 0
no network-clock-participate aim 1
no aaa new-model
ip subnet-zero
ip cef
ip domain name hrtransit.org
no ftp-server write-enable
username xxxx privilege 15 secret xxxxx
interface FastEthernet0/0
description LAN Router Connection at Silver Leaf
ip address 172.x.x.x.255.255.0
duplex full
speed 100
interface FastEthernet0/1
description BU LAN Router Connection at Silver Leaf
ip address 192.168.16.16 255.255.252.0
duplex auto
speed auto
interface FastEthernet0/1/0
no ip address
duplex full
speed 100
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
no ip address
interface Serial0/2/0
ip address 172.x.x.x.255.255.252
encapsulation ppp
interface Serial0/3/0
no ip address
clockrate 2000000
interface Serial0/3/1
no ip address
clockrate 2000000
interface Vlan1
description Silverleaf Switch
router rip
version 2
network 172.16.0.0
no auto-summary
ip default-gateway 172.16.5.1
ip classless
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
control-plane
banner login ^C
Cisco Router and Security Device Manager (SDM) is installed on this device.
This feature requires the one-time use of the username "cisco"
with the password "cisco".
Please change these publicly known initial credentials using SDM or the IOS CLI.
Here are the Cisco IOS commands.
username <myuser> privilege 15 secret 0 <mypassword>
no username cisco
Replace <myuser> and <mypassword> with the username and password you want to use.
For more information about SDM please follow the instructions in the QUICK START
GUIDE for your router or go to http://www.cisco.com/go/sdm
^C
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
Roberto Salazar Wed, 04/12/2006 - 11:43
  • Gold, 750 points or more
>>>Where is the switch connected to? How is that switch connecting to this router? Where are you pinging the 172.16.5.5 from? From this router?
>> What is 5.1 port?
Thanks for your response. The switch is a 9 pt HWIC...see http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_feature_guide09186a00802c6bb6.html....it is a module mouted in the router lick a serial module or a T-1 module etc...I read the installation documentation for the HWIC switch but does not work. I know its a router/switch thing since its a module so I not sure that I can configure it like that. I have another config that works but this has me wondering why if its the same subnet on the same device that I can not ping 5.5 or any other 5.0
I found my answer....helps to read
Thanks again
Restrictions for EtherSwitch HWICs
The following restrictions apply to the Cisco HWIC-4ESW and the Cisco HWIC-D-9ESW EtherSwitch HWICs.
•No more than two Ethernet Switch HWICs or network modules may be installed in a host router.
Multiple Ethernet Switch HWICs or network modules installed in a host router will not act independently of each other. They must be stacked, as they will not work at all otherwise.
•The ports of a Cisco EtherSwitch HWIC must NOT be connected to the Fast Ethernet/Gigabit onboard ports of the router.
•There is no inline power on the ninth port (port 8) of the HWIC-D-9ESW card.
•There is no Auto MDIX support on the ninth port (port 8) of the HWIC-D-9ESW card when either speed or duplex is not set to auto.
•There is no support for online insertion/removal (OIR) of the EtherSwitch HWICs.
•When Ethernet Switches have been installed and configured in a host router, OIR of the CompactFlash memory card in the router must not occur. OIR of the CompactFlash memory card will compromise the configuration of the Ethernet Switches.
•VTP pruning is not supported.
•There is a limit of 200 secure MAC addresses per module that can be supported by an EtherSwitch HWIC.
