users losing their connections
Apr 12th, 2006
I am having users lose their dial-up connection after only being connected for 2 to 10 minuntes at a time. This is happening sporadically and while some users on getting connecting and is not have any problems. I usually will reboot the device and the problems go away for a short period of time.
The devices are As5300 with 4 T1's and PRI setup with a basic config. The modems or MICA modems. I have tried to see what going on by looking at what line and modem the individual is on and issueing the Show modem operational-status on the modem.
Does any one know of a better why to troubleshoot this type of issues for a newbie??
Any help would be greatly appreciated.
renoufi Wed, 04/12/2006 - 17:11
The following debug commands my come in useful
debug modem
debug spe modem
debug isdn events
debug isdn q931
ekeen Wed, 04/12/2006 - 17:28
Thanks Renoufi,
Should I use this globle or just on the individuals that are having problems?
renoufi Wed, 04/12/2006 - 19:07
They are all global commmands. This can make them hard to read on a busy system. Try to use them at a quiet time or activate them one at a time.
You will need to use:
>: term moni
to see the debug messages if you are using telnet to connect to the console
If the screen goes hay wire with 1000's of messages just type
>: u all
which is undebug all. It may take a couple of seconds for the screen to stop scrolling if the system is busy.
