Warning message
how to use default route achieving load-balancing?
Answered Question
Apr 12th, 2006
show me an example
thanks
Correct Answer by pkhatri about 11 years 4 months ago
Try this:
ip cef
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Serial1
With the above config, the router will perform per-destination load-balancing. So for example, a session to IP 10.1.1.1 may go over Serial0 while the session to IP 192.168.1.1 may go over Serial1.
Pls do remember to rate posts.
Paresh
Overall Rating: 5 (1 ratings)
ankurbhasin Wed, 04/12/2006 - 21:17
  • Red, 2250 points or more
Hi Friend,
If you have 2 default route with same admin distance you can have equa load balancing.
Something like this
Now because these 2 default routes have equal admin distance so both will be peferred and will result into equal load ballancing.
HTH, if yes please rate the post.
Ankur
Correct Answer
pkhatri Wed, 04/12/2006 - 21:18
  • Purple, 4500 points or more
Try this:
ip cef
Paresh
