CCM 3.3.4sr2 to CCM 4.1.3 upgrade
Apr 13th, 2006
  • Bronze, 100 points or more
I am having problem with upgrade, I ran upgrade assistance and it confirms that my machine is ready for upgrade. During the installation, it asks me to insert disk1 of disk2 installation, upgrade, and recovery.But, I do have disk1 in cdrom and it fails to recongize it.
Any ideas or suggestions, I seems to cant go before this point.
I have 2 gig ram on server.
thanks
travis-dennis_2 Thu, 04/13/2006 - 01:24
  • Gold, 750 points or more
2 things to check.
1) Is the disk that you have a DVD or a CD and if DVD do you have a DVD drive on the server
2) Verify that the CD Drive will read other CDs
Hope this helps.
Please remember to rate all replies
thisisshanky Sat, 04/15/2006 - 08:34
  • Purple, 4500 points or more
Are you using the right disks ? CM4.13 disks have "Callmanager 4.13" labelled on the front as well as "Disk1" and "Disk2" clearly labelled.
spatel_64 Tue, 04/18/2006 - 05:48
There is download on CCO ciscocm-ffu.4-1-3.exe. Make sure your OS is at atleast 2000.2.7. You can download this file from CCO. This will be easy upgrade then CDS.
SP
