Warning message
trunking between a router and a switch
Answered Question
Apr 13th, 2006
i used the topology and the configuration described on the pictures included on this post.. but the problem that the ping failed between the switch and the router
Correct Answer by Roberto Salazar about 11 years 4 months ago
conf t
int fa 0/0.1
ip address blah
encapsulation dot1q 1 native
Overall Rating: 5 (1 ratings)
Roberto Salazar Thu, 04/13/2006 - 09:45
  • Gold, 750 points or more
The router config might not have been captured correctly coz it would not allow you to configure the subinterface with no vlan id after the encapsulation. But you can try this, define the native vlan 1 on the router's subtinterface for subnet 172.16.1.0/24. Also, what address of the router are you pinging from the switch?
omar_elmohri Thu, 04/13/2006 - 09:54
thx,
how i can define the native vlan 1?
do you mean that i use a subinterface as vlan1?
i did this at first and i defined it's ip address as 172.16.1.1/24
the address i tried to ping is 172.16.1.1/24
Correct Answer
Roberto Salazar Thu, 04/13/2006 - 10:05
conf t
int fa 0/0.1
ip address blah
Roberto Salazar Thu, 04/13/2006 - 12:13
Okay, so you forgot to put in the vlan. Great.
Please rate helpful posts.
