Warning message
Changing IP on IP Express
Brandon Buffin Fri, 04/14/2006 - 06:54
  • Purple, 4500 points or more
Dave,
Here are a few things to keep in mind.
1. Change the local LAN interface address.
2. Be sure to change your DHCP pool/pools including network, default-router, and option 150.
3. Change the service-module ip address and default-gateway for the service-engine interface for CUE.
4. Change the session target for the dial-peer(s) pointing to CUE.
5. Change the ip source-address under telephony-service.
Hope this helps. If so, please rate the post.
Brandon
