Warning message
VPN Router
Apr 14th, 2006
  • Silver, 250 points or more
HI,
is there any VPN router in cisco, where i need to access my office network from my laptop at home over the internet. my laptop has got Linux/windows xp.
So far i have installed a software based vpn on linux box & i am using it, now my management has agreed to purchase a hardware vpn box, so i thought i will go in for cisco, i think pix will do that, hardly 3 or 4 ppl. will be accessing the office network from the internet when ever they are on the move. so can some one suggest me for a lower cost, because only 4 ppl. might be using it including me.
m.sir Fri, 04/14/2006 - 03:41
  • Gold, 750 points or more
according this document
http://www.cisco.com/en/US/products/sw/secursw/ps5299/index.html
Cisco Easy VPN Remote is now available on Cisco 800, 1700, 1800, 2800, 3800, and UBR900 Series routers, Cisco PIX 501 and 506E security appliances, and Cisco VPN 3002 Hardware Clients. The Cisco Easy VPN Server is available on numerous Cisco VPN routers including the Cisco 800, 1700, 1800, 2800, 3800, and 7200 Series routers, Cisco 7301, Cisco PIX security appliances, and all Cisco VPN 3000 Concentrators
Regarding Cisco VPN Server - Client configuration try this document
http://www.cisco.com/application/pdf/en/us/guest/products/ps6659/c1650/cdccont_0900aecd80313bdf.pdf
M.
Hope that helps, rate if it does
