Log Analyzer Recommendation needed
Apr 14th, 2006
I am trying to find a log analyzer (unix/windows/linux based)for PIX 525. is there anyone out there who has experience with this? what would you recommend?
thanks
Ercan
Patrick Laidlaw Fri, 04/14/2006 - 12:31
  • Gold, 750 points or more
Most of my experience with logs is that most companys write scripts to parse there logs into different event types/connections and then export the numbers and log entrys that didn't fit for manual views.
Patrick
