DeviceTypeMismatch error in event log for phone that works fine
Apr 14th, 2006
  • Silver, 250 points or more
Anyone ever see a error on devicetypemismatch for a phone that has been working on system previously and programmed for awhile? This is a 7920 phone which I can understand will come and go depending on wireless, but a device mismatch error? This is on 4.1(3)sr1 and I checked for bugs and release notes and nada on devicetypemismatch.
Any one have list of database device types or know what 30002 is?
Event Type: Error
Event Source: Cisco CallManager
Event Category: None
Event ID: 3
Date: 4/14/2006
Time: 1:50:55 PM
User: N/A
Computer: CALLMANAGER
Description:
Error: DeviceTypeMismatch - Device type mismatch.
Name of device.: SEP0014F2C86427
UNKNOWN_PARAMTYPE:Device type: 7
UNKNOWN_PARAMTYPE:Database device type: 30002
App ID: Cisco CallManager
Cluster ID: StandAloneCluster
Node ID: x.x.x.x
Explanation: Device type passed on by the indicated device does not
match the database configuration.
Recommended Action: Verify database configuration for the indicated
device..
FROM CCM DETAILED TRACES:
04/14/2006 13:50:55.776 CCM|New connection accepted. DeviceName=, TCPPid
= [1.100.132.3085], IPAddr=x.x.x.x, Port=0, Device
Controller=[0,0,0]|<CLID::StandAloneCluster><NID::x.x.x.x><CT::0,0,
0,0.0><IP::><DEV::>
04/14/2006 13:50:55.792 CCM|StationInit: (0000000) alarmSeverity=2
text="25: Name=SEP0014F2C86427 Load=4.0(02.00) Last=CM-ICMP-Unreach"
parm1=2049(801)
parm2=1234(4d2).|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,
119,1.2520693><IP::x.x.x.x><DEV::>
04/14/2006 13:50:55.808 CCM|StationInit: (0000000) InboundStim -
StationRegisterMessageID: Msg Size(received, defined) = 48,
56|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.2520694>
StationRegisterMessageId [Normal Device priority]:
|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.2520694><I
P::x.x.x.x><DEV::>
04/14/2006 13:50:55.808 CCM|Processing StationReg. regCount: 1
DeviceName=SEP0014F2C86427, TCPPid = [1.100.132.3085],
Controller=[1,118,2344]|<CLID::StandAloneCluster><NID::10.117.30.10><CT:
:1,100,119,1.2520695><IP::x.x.x.x><DEV::SEP0014F2C86427>
CCM|dBProcs::readStationRegistrationProfileByDeviceName
started|<CLID::StandAloneCluster><NID::x.x.x.x>
04/14/2006 13:50:55.808 CCM|dBProcs - hash find device start, num of
Caching Entries = 307|<CLID::StandAloneCluster><NID::x.x.x.x>
04/14/2006 13:50:55.808 CCM|dBProcs - hash find device end, num of
04/14/2006 13:50:55.808 CCM|StationD: (0002344) ClusterSecurityMode =
(0) DeviceSecurityMode =
(1)|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.2520695
04/14/2006 13:50:55.808 CCM|DeviceTypeMismatch - Device type mismatch.
Name of device.:SEP0014F2C86427 UNKNOWN_PARAMTYPE:Device type:7
UNKNOWN_PARAMTYPE:Database device type:30002 App ID:Cisco CallManager
Cluster ID:StandAloneCluster Node
P0014F2C86427><DEV::SEP0014F2C86427>
registrationProfile_discovery_DbStationRegistrationProfileRes sent
StationOutputRegisterReject|<CLID::StandAloneCluster><NID::x.x.x.x>
<CT::1,100,119,1.2520695><IP::x.x.x.x><DEV::SEP0014F2C86427>
04/14/2006 13:50:55.808 CCM|StationD: (0002344) RegisterReject
text='Error: Device type
mismatch'.|<CLID::StandAloneCluster><NID::x.x.x.x><CT::1,100,119,1.
a-vazquez Thu, 04/20/2006 - 08:35
The problem could be because of OS7920.txt file not updated with the correct phone load version. There could be a mismatch in the file. Update the file to the current load version and phones would register okay.
