Configure DSP for conferencing on 3825 Router problem
Answered Question
Apr 16th, 2006
Hi Pros,
I am trying to utilize PVDM2-64 on 3825 Router for conference bridge. I have made all configs as per CCO Docs. But still I am unable to get it running.
When I configure SCCP, then create a profile for conferencing, it shows option for maximum sessions as 0 only. Due to that I am unable to no shutdown the profile.
I am attaching a show tech-support of the router. Please let me know if I am missing any commands or any specific sequence needs to be followed.
Pratik
PS: A brief config below...
voice-card 0
dspfarm
dsp services dspfarm
interface GigabitEthernet0/0
description *** Connected to Core Switch 2 on VLAN 20 ***
ip address 10.212.74.1 255.255.255.0
duplex auto
speed auto
media-type rj45
negotiation auto
h323-gateway voip interface
h323-gateway voip h323-id TRAN
h323-gateway voip bind srcaddr 10.212.74.1
sccp local GigabitEthernet0/0
sccp ccm 23.132.8.12 identifier 1 version 4.0
sccp ip precedence 3
sccp
sccp ccm group 1
description *** For Ascot users ***
associate ccm 1 priority 1
associate profile 1 register ASCOTDSPFARM1
dspfarm profile 1 conference
description *** For Ascot Users ***
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
associate application SCCP
shutdown
gateway
timer receive-rtp 1200
Correct Answer by thisisshanky about 11 years 4 months ago
I see you have two E1s. Are you using both ? Your sh inventory output shows u have have 64 channel DSP and both E1s are configured. The problem here is that you dont have enough DSP resources for conferencing. If you are not using the second E1, try removing the pri-group command from that E1 controller and that should help!
Sankar
PS: please remember to rate posts!
Overall Rating: 3.5 (2 ratings)
Correct Answer
thisisshanky Sun, 04/16/2006 - 09:27
  • Purple, 4500 points or more
Sankar
pratik.rb Mon, 04/17/2006 - 00:10
Hi Sankar,
Thanks for the info. Worked like a charm. Didnt realize those DSPs are required for voice too...
Pratik
