SDM error
Apr 17th, 2006
I am looking at installing SDM on our network. I am able to install the software on both the PC (Window XP SP2) and on the router (2610XM, 12.4(5a)) and configure the basics for the two to communicate. When I open the SDM Launcher and put in the IP address of the router, I get the login prompt as expected. Once I enter in the username/password, a new explorer window pops up with what I am assuming is an error. I am unable to actually get into the router. Please see the attached document for the error message I receive. Any help would be appreciated.
Overall Rating: 5 (2 ratings)
reswaran Tue, 04/18/2006 - 06:02
  • Cisco Employee,
To fix this problem, you need to go to IE's Tools/Internet Options and click the Advanced tab, scroll down to Security section, and check "Allow active contents to run in files on My Computer". Then close IE and relaunch SDM.
Please try to set the following and check it out.
Ravi
