Replacing faulty sup720
Apr 17th, 2006
  • Bronze, 100 points or more
Sup720 did not pass diag tests. Need to replace it. Are there any special instructions to replace faulty sup720? Only one sup720 (6513,IOS), no redundant sup.
Thanks.
Overall Rating: 5 (1 ratings)
Bobby Thekkekandam Mon, 04/17/2006 - 09:51
  • Cisco Employee,
If you have your configuration backed up already, then all you should need to do is power down the switch (since we don't have redundant sups), insert the replacement supervisor, power the switch up, ensure that you are running the desired IOS version, and then load your config from a flash device or TFTP server.
HTH,
Bobby
*Please rate helpful posts.
