I got a error message from ACS 3.3
I running ACS 3.3 over six months and running smoothly , Recently i got a error message from ACS server
From "External User Database" -> "Database Group Mappings" -> "Windows Database" -> Select "AD Domain" -> "add mapping" -> Got Fail Message "Failed to enumerate windows group , If you are using Active Directory consult the installation guide for information"
Anyone can tell me how to resolve the problem
darpotter Wed, 04/19/2006 - 00:46
  • Silver, 250 points or more
You need to set logging to max, then manually re-start CSAdmin from the control panel. Try the UI page again then save the csadmin/logs/adm.log file.
Most likely something within your AD network has changed if ACS has suddenly stopped working.
Anyway, you may need to open a TAC case because tracking down AD problems can be long winded.
Darran
