Warning message
CUE Editor
Apr 18th, 2006
have cue 2.2.1 and trying to edit script.
seem to get to a point in adding steps where it will not let me save or copy/paste any more.
Is there a limitation to number of steps in a cue script?
Running cue editor on xp pc with all the sp's.
thomas.chen Tue, 04/25/2006 - 07:20
  • Silver, 250 points or more
Is there anything special about the Win2K/XP Pro that you are installing? Any service packs etc? Could there be any security/antivirus settings which are not allowing the JVM to start? You could try disabling such applications and give it a try. Maybe the event logs (application/system/security) might give some more information.
