ip2ip gateway memory problem
Apr 19th, 2006
I have a vary strange problem.. memory on cisco 3660 strangely decrease seriusly. I got the following sip error:
SIP/2.0 400 Bad Request - 'Malformed/Missing Contact field'
when I do not get that error there is no memory problem !!!???
Overall Rating: 4.5 (2 ratings)
jaymare33 Thu, 04/20/2006 - 00:15
with debug errors I still get the following errors..
SIP: (505) fmtp attribute, level 1 instance 2 not found.
//505/B2F804228F67/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to acquire event mask for rfc2833 dtmf relay
SIP: (507) fmtp attribute, level 1 instance 2 not found.
//507/B36A28A18F69/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to acquire event mask for rfc2833 dtmf relay
SIP: (509) Attribute ptime, level 1 instance 1 not found.
SIP: (509) fmtp attribute, level 1 instance 8 not found.
//509/AD9F68D18038/SIP/Error/sipSPI_ipip_copy_sdp_to_channelInfo: Unable to acquire event mask for rtp dtmf relay
//-1/xxxxxxxxxxxx/SIP/Error/rtpAvpCodec_to_voipCodec: Unexpected RTP PayloadType :19 in SDP Body
I can't find any resource to troubleshoot the problem.. anyone can help please?
David Stanford Thu, 04/20/2006 - 06:30
  • Cisco Employee,
Hmm...it looks like the gateway is communicating to some SIP proxy/server and complaining that either To/From headers in one of the messages is wrong
you might want to take a look at a 'debug ccsip messages' or 'debug ccsip all' for this. We need to look at the INVITE message and see what the GW is complaining about, and if it's a correct complaint or not
if the GW is up to code, it might be that the server may be sending a non rfc compliant INVITE request
The second set of messages you provided are normal and don't indicate any problems
