pkhatri Thu, 04/20/2006 - 20:30
  • Purple, 4500 points or more
Hi Gopal,
They are one and the same thing...dot1q is simply used as an abbreviation for 802.1q.
Pls do remember to rate posts.
Paresh
gopal_4476 Thu, 04/20/2006 - 20:42
Hi pkhatri,
thanks for your immediate reply
still i am confused... could you explain it in detail
Gopal
pkhatri Thu, 04/20/2006 - 20:45
Gopal,
What I am saying is that there is no difference between saying 802.1q and dot1q - they refer to the same thing.
The IEEE 802.1q specifies a 4-byte header which can be used in order to tag ethernet frames in order to associated them with a virtual LAN. The actual VLAN ID is 12 bits, giving you a theoretical maximum of 4096 VLANs.
Pls do remember to rate posts that help.
Paresh
csco10837896 Thu, 04/20/2006 - 21:05
802.1Q & dot1q one at same.
802.1Q its IEEE standard .
When you are trying to configure on switch command is dot1q
Pls Rate this post
Yogesh
