Unity 4.05
Overall Rating: 3 (1 ratings)
gogasca Fri, 04/21/2006 - 15:50
  • Green, 3000 points or more
Hi Eric
Per your email address, I will assume you are using french locale.
CSCsb43338
Symptom:
When attempting to check a message using the French Language after a message is read you should hear the Day and the Time the message was left. When listening to the message using the French prompts only the Time is heard and not the Day.
When playing the same message using English Language the Day and Time are told after the message is read.
Conditions:
Unity 4.0.5
Exchange 2000 on box
French Language being used
Workaround:
No work around for French Language. Works fine for English Language
It is fix in 4.0(5)ES27. So you may open a TAC case so they send u the ES.
For the question message u may use Message Notification feature in Unity.
//G
bvanturn Sat, 04/22/2006 - 01:25
  • Cisco Employee,
Some of the Unity ES are also available on CCO for download at this location (for Unity 4.0(5))
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/prod_release_note09186a0080599ea7.html
So this is the file you should be looking for I think in case you are indeed hitting the bug mentioned above.
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps2237/prod_release_note09186a008054093b.html
It's advisable only to install ES if you are really sure that you need them, if you are not sure open a TAC case for it so a TAC engineer can identify the problem and supply you with an optimal solution.
