Warning message
yshraybman Sat, 04/22/2006 - 11:52
  • Bronze, 100 points or more
Just like any other phone. When ATA registers with CME first time, CME automatically creates dynamic ephones. For ex: last configured ephone is 10, CME will create ephone 11 and 12. Notice the MACs and put them under ephone config of your choice. ATA must be unregistered in order to move ATA MAC between ephones.
If you already know MACs you can configure ephones beforehands and you'll be done.
Configure ephone-dn like any other phone.
ephone-dn 7
number 4907
label 4907
description Fax
name Fax
ephone 7
username "xxx" password xxx
mac-address ATA-MAC-line1
type ata
button 1:7
Same thing for line 2
thisisshanky Sat, 04/22/2006 - 22:43
  • Purple, 4500 points or more
If mac of ata is 00075234AA32 use this for primary port.
For second port try, 075234AA3201. (Shift the left most two digits and add a 01 at the end).
yshraybman Sun, 04/23/2006 - 15:25
Let ATA register with CME for the first time, then do 'show ephone ata' and you will see 2 MACs.
thisisshanky Tue, 04/25/2006 - 05:46
I am interested in knowing which solution worked for you ?
