Warning message
BGP route maps for setting local pref
mheusinger Fri, 04/21/2006 - 13:41
  • Green, 3000 points or more
this will work, because a route-map statement without match condition will match everything.
Hope this helps! Please rate all posts.
Regards, Martin
fabricio.monte Fri, 04/21/2006 - 13:42
Hello Patrick,
Your config will work.
If you want to match everything, you don't need to use the "match" statement, just use the "set" statement.
You will need to use the "match" only if you want to select something.
Fabricio
Network Analyst
