VPN issue
Apr 23rd, 2006
Hi Guys,
I have a pair of ASA 5500 with ipsec tunnel in between. The issue is I am able to "ping" and connect to most of the nodes on the other side of the network but not all the nodes, especially those networked printers. I checked ip,mask and gateway and they are all correct. I amm also able to "ping" those nodes in the internal network (not remote side. Please help!!!!
Thank you so much
John
the other site
b.speltz Mon, 05/01/2006 - 05:18
  • Bronze, 100 points or more
Check for any filtering of IP address like access list in the remote side router and also for ICMP
Fernando_Meza Mon, 05/01/2006 - 17:31
  • Gold, 750 points or more
you need to check what is in between the ASA at the remote site and those networked printers ...
I am assuming there is no filters on both ASAs for the IPsec tunnel us that correct ..?
