ACLs on Sub-Interfaces
Answered Question
Apr 23rd, 2006
Question on IP ACL...
If you configure an IP ACL for a subinterface on a router-on-a-stick, will it affect the entire physical interface or will it only affect the sub-interface, for which the ACL has been applied to? Just a thought that's been bugging me...Advanced thanks for your response...
Correct Answer by pkhatri about 11 years 3 months ago
It will only affect the sub-interface. The ACL applies only to the logical construct which is the sub-interface.
Hope that helps - pls do remember to rate posts that help.
Paresh
Overall Rating: 4 (2 ratings)
Correct Answer
pkhatri Sun, 04/23/2006 - 20:51
  • Purple, 4500 points or more
Paresh
