Update Ring Tones for 7920 Wireless phone W/ CCME
Apr 24th, 2006
We're trying to figure out a way to update the ring tones on a 7920 wireless phone with CCME. Does anyone have a link or a procedure on how to do this. We do not have a USB cable in order to get into the 7920 utility.
smalkeric Fri, 04/28/2006 - 07:51
  • Silver, 250 points or more
Installing ring tones on a CCME router is a three step process. First, you need to obtain ring tone audio files - these are 8khz 8-bit mono u-Law WAV audio files (just like Music on Hold). You then need to create a RingList.xml file which lists the display names of the ringers, and their file name. Then you need to TFTP those files onto your router, and create a "tftp-server flash:" entry for RingList.xml, and each ring tone individually.
There are 45 ringtones for Cisco 7920/7940/7960 sets on the Quick Links bar. You can open them with WinZip and extract them to a directory. Then make a RingList.xml that looks like this:
Indian Call
indiancall.raw
Cartoon Split
cartoonsplit.raw
This URL should help you:
http://www.cisco.com/univercd/cc/td/doc/product/voice/c_callmg/3_0/admin_gd/3_0_9/a3rings.htm
