Warning message
rip v2 advertisements
Apr 24th, 2006
If I have a router advertiseing the network 172.16.38.0/24 running rip v1 and another router running rip v2 with the no auto summary command configured, and also advertising the same network , what will the difference be in the routing table ?
stephtchoko Mon, 04/24/2006 - 10:14
  • Bronze, 100 points or more
rip version 1 is a classfull protocol, automaticaly summary at boundary and it doesn't advertise subnet mask in rounting exchange.
rip version 2 is classless protocol, automaticaly summarise at classful boundary, if your disable autosummary; it 'll advertise a subnet at classfull boundary.
Please hope this help and rate this post.
carl_townshend Mon, 04/24/2006 - 14:44
Would this to be neighbouring routers or only when it goes through a router on a different subnet ? Also does rip send updates to only its neighbours on the same subnet, whereas eigrp sends them to all known routers in its table ?
stephtchoko Tue, 04/25/2006 - 00:35
rip v1 use broadcast to exchange routing information with its neighbors
rip v2 use muticast 224.0.0.9 to exchange routing information with its neighbor
with rip network command is to put a particular network on rip database. router Rip have :
- neighbor table
- routing table
Eigrp use multicast 224.0.0.10 to exchange routing information. Eigrp router have 3 tables:
-topology table
-neighbor table
-routing table
for 2 eigrp router can be neighbor if :
- AS is match
- metric is match
-send hello on interface to which neighboring 'll be negociated
Eigrp router send network learn by eigrp to its neighbor, not to all know router.
please don't forget to rate this post.
Regards.
