Secure ACS 4.0 / local authentication
Apr 24th, 2006
Hey all,
I'm sure this is a very simple problem but I can't seem to get local authentication done as a second choice on any device if I use radius. It works if I use tacacs+. The lines I have set in AAA are:
aaa authentication login default group cwtest001 local-case
aaa authentication dot1x default group cwtest001 none
aaa authorization config-commands
aaa authorization exec default group cwtest001 local
aaa authorization network default group cwtest001
aaa accounting auth-proxy default start-stop group tacacs+
where cwtest001 has been defined.
This line in question:
I have tried every variation I can think of (I think). From SecureACS side, the device is set to use Radius IETF as authentication. I can log into the device without a problem using network credentials but in case this server goes down, I want the ability to use a local account on the device as backup.
Any help is appreciated.
Thanks!
s.jankowski Fri, 04/28/2006 - 10:40
  • Bronze, 100 points or more
You have set the authentication to Local. Are you sure, you have the user name and password configured in the local database?. Because, you might have mistakenly missed out that information to be added.
scottmac Fri, 04/28/2006 - 15:01
  • Green, 3000 points or more
For Cisco APs, set the ACS up for Cisco Wireless.
If you're not GUI-phobic, set up the RADIUS server/local auth according to their preferred order in the WebGUI on the security page.
How many users/userids do you have?
The local RADIUS / user base can only handle ~50 entities (and I think that's a hard-limited count).
Good Luck
Scott
Trending Topics - Security & Network
