Warning message
Policy routing problem
Apr 24th, 2006
Q:- If you have configured route redistribution between separate routing domains and have included route filters to prevent route feedback, which command would you use on a boundary router to verify that redistribution is working correctly?
A. show ip protocols
B. trace
C. show ip access-lists
D. ping
Q:- On Cisco routers, fast switching of policy-based routing _____.
A. is not supported
B. requires the ip fast policy interface configuration command
C. requires the ip fast policy router configuration command
D. requires the ip route-cache policy router configuration command
E. requires the ip route-cache policy interface configuration command
Mahi
Overall Rating: 5 (1 ratings)
Patrick Laidlaw Tue, 04/25/2006 - 00:35
  • Gold, 750 points or more
Question 1 is "show ip protocols"
Question 2 I've got to look up but for some reason i want to say the answer is (A)
Can someone give a crack at question 2 and give us a firm answer.
Patrick
rawatmohinder Tue, 04/25/2006 - 02:10
For first question A is not a correct answer... But i don,t know the correct one..
Kindly help me out...
Mahi
pkhatri Tue, 04/25/2006 - 02:14
  • Purple, 4500 points or more
Mahi,
I believe the answer should be B. The reason is that a traceroute will show you the presence of a routing loop, which is a frequent result of route feedback when redistributing protocols.
Hope that helps - pls do remember to rate posts that help.
Paresh
